Kingston® HyperX® Predator memory features fast speeds, low latencies and high capacities.
Push your system to the max. Kingston® HyperX® Predator takes performance to thrilling new extremes with the fastest speeds, lowest latencies and highest capacities available in HyperX memory. It has a new heat spreader for greater heat dissipation, plus it's Intel XMP Certified and compatible with all popular brands of motherboards.
HyperX Predator is ultra-reliable and 100-percent factory tested to ensure higher performance, ultra-responsive multitasking and a faster system. Users can overclock their platforms simply by selecting a profile, with no need for manual adjustments in BIOS. HyperX Predator is backed by a lifetime warranty, free technical support and legendary Kingston reliability.
- Compatible -- tested with all popular brands of motherboards
- Reliable -- 100-percent factory tested
- Easy to install
- Guaranteed -- lifetime warranty, free technical support
- Dense heat spreader for ultimate heat dissipation
- Intel XMP Certified
