IronKey Personal is a revolutionary personal security device designed to protect your data, passwords and online identity on any computer. All data stored on an IronKey Personal drive is encrypted with high-speed military-grade hardware encryption. Unlike software-based encryption, this "always-on" protection cannot be disabled and is protected against cold-boot and brute force attacks. No one can access files stored on an IronKey unless they authenticate with the correct password. All encryption and password verification are performed in hardware, and it cannot be disabled by worms, viruses or other malware. D250 drives balance performance and value for users who don’t require constant access to data. The same great security as the S250, the D250 has dual-channel MLC flash memory for reliable read/write performance. Shielded in a solid, tamper-resistant and waterproof metal casing that surrounds specially sealed internal components, IronKey drives are built to survive years of wear and tear. Each IronKey drive is pre-configured with a client-side secure digital certificate, which can be used for strong authentication (VeriSign Identity Protection service) to participating websites. IronKey also provides a PKCS #11 interface which will allow any Windows application to potentially use the certificate.
