Back
Generic Memory
Kingston 16GB DDR4 2400MHz SODIMM Memory
Quicklinx:
CQSPWS00
Mfr#:
KCP424SD8/16
Back
Kingston - DDR4 - 16 GB - SO-DIMM 260-pin - 2400 MHz / PC4-19200 - 1.2 V - unbuffered - non-ECC
Kingston - DDR4 - module - 16 GB - SO-DIMM 260-pin - 2400 MHz / PC4-19200 - unbuffered
Memory module
16 GB
Memory Type
DDR4 SDRAM - SO-DIMM 260-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2400 MHz (PC4-19200)
Dual rank, unbuffered
Voltage
1.2 V
Limited lifetime warranty (Russia - 10 years)
16 GB
Upgrade Type
Generic
DRAM memory module
DDR4 SDRAM
SO-DIMM 260-pin
Speed
Non-ECC
Module Configuration
2048 x 64
Chips Organization
X8
Voltage
1.2 V
