Please Note: This is only the Dual Monitor Arm, not the full Workstation. This needs to be purchased with KW55792WW - Quicklinx BWGP
Take productivity to a professional level by adding a dual monitor arm to your SmartFit Sit/Stand Workstation. Studies have shown using two monitors can have a dramatic effect on workflow. With dual monitors on your workstation, not only are you getting the ergonomic and health benefits of standing while you work, youre also getting a lot more work done. Our patented SmartFit System lets you find your personal comfort color to set the monitors at the ideal viewing height, plus the arm installs quickly to your Sit/Stand workstation and is VESA-compatible for monitor screens up to 24 inches.
