With space for 10 iPads and the ability to stack up to 3 cabinets, the Kensington Charge & Sync Cabinet is the smart solution. Each iPad cabinet is secured to a table with the included mounting plate or a cable lock. To simplify charging and syncing, youll find easy access to each iPad or iPad mini 30-pin or Lightning cable connector port (cable not included). A single power cord provides charging for the entire cabinet. Theres even a built-in fan to keep your iPads cool.
