Featuring dual lenses, the X360 is the ultimate user friendly 360ยบ camera. Use the smartphone app to control the X360 remotely and preview your shots to always get the perfect footage.
Explore the world unlike never before; in full 360-degree views. Capture unbelievable vision through the X360 dual lens, relive your experiences in virtual reality or share your footage for the world to see on the Internet. The front and rear lenses each capture 180-degrees horizontally and vertically, creating a seamless and complete 360-degree field of view.
Make your own virtual reality HD videos
The X360 videos are watchable trough the VR-X headset. Because of this, the X360 could be just what content creators need to start making quality 360-degree video.
Pair up your smartphone via Wi-Fi
You can watch, pan around and share your content from your smartphone or tablet.
Lightweight design
Compact in design and lightweight, the X360 Dual Lens VR camera's dome shaped lenses allows the user to record footage in 360-degree panorama mode, ensuring you to capture every moment, of every experience, from every conceivable angle.
Kaiser Baas X360 Dual Lens VR - action camera
Action camera - compact
Action Camera Type
Mountable
Memory Card Slot
microSD card
Wireless Interface
Wireless LAN
Sensor Resolution
2 x 4.0 Megapixel
Max Video Resolution
1920 x 960
Lens System
2 x fisheye lens 1.1 mm f/2.0
Display
LCD display - 1.5"
Supported Battery
Li-ion rechargeable battery - 1500 mAh (included)
USB 2.0
6 cm x 5 cm x 4.8 cm
106 g
Sensor Resolution
2 x 4.0 Megapixel
360° Camera
Optical Sensor Type
CMOS
Digital Video Format
H.264, MOV
Image Recording Format
JPEG
1920 x 960
USB 2.0, Wireless LAN
Connectivity Features
Remote control via mobile devices, remote live view, Wireless Image Transfer
Lens System
2 x fisheye lens 1.1 f/2.0
Max View Angle
180 degree(s)
Additional Features
Additional Features
Auto power save
Action Camera Features
Camera Type
Mountable
360° Camera
Optical Sensor Qty
2
Display
1.5" LCD display
Display Form Factor
Built-in
Microphone
Microphone Operation Mode
Mono
Connector Type
USB
Cleaning cloth, tripod, USB cable, tripod adapter, curved adhesive mount, flat adhesive mount, quick release mount, carrying bag
