The Juice 3 Charge Power Bank with 10,000mAh (Three Full Charges) battery capacity. The perfect accessory for a day or two off the grid – if you know you'll be without mains power for your little staycation or special trip away this year, don't forget to pack the Juice 3 Charge Power Bank to make sure all your devices are powered up. Don't want to miss the perfect photo op!
The Juice 3 charges an average smartphone from 0-50% battery in only fifty minutes and holds three complete charges of an average smartphone. With a digital battery level display to check remaining energy levels – you should never get caught out!
Oh, and if you're feeling generous the Juice 3 Charge Power Bank allows you to charge two devices at once. So, if you have a friend in need you can always give them a quick power boost whilst you both charge up.
All Juice Power Banks come with a 12month warranty.
Specifications:
Input 1: Micro USB DC5V/2A
Input 2: Type C DC5V/2A
Output 1: USB A DC 5V/2. 1Amp (max)
Output 2: TYPE C DC 5V/2. 4Amp (max)
Total Output: DC 5V/2. 4Amp (max)
CE Certified
Dimensions
W x D x H (cm): 9.3 x 6 x 2.5
