The legendary JBL Signature sound as found in theaters, arenas and studios around the world is now available in a headphone.
Active noise canceling reduces outside noise for a more immersive sound experience.
Enjoy crystal clear wireless sound and convenient hands-free calling.
A rapid two-hour charging gets you up to 24 hours of playback.
Effortlessly switch from music on your portable device to a call from your phone, so that you never miss a call.
Optimized ergonomic design and soft touch material allows for a better fit and longer more comfortable listening sessions.
Allows easy management of music and calls from virtually every portable device.
- JBL E65BTNC - headphones with mic - 3.5 mm jack
- Product Type
- Headphones - Bluetooth - wireless - 3.5 mm jack
- Recommended Use
- Portable electronics
- Matte black
- Headphones Form Factor
- Full size
- Foldable
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Radio Frequency Range
- 2.402 - 2.480GHz
- Bluetooth Version
- Bluetooth 4.1
- Sound Output Mode
- Stereo
- Sound Effects
- Signature Sound
- Audio Specifications
- Frequency Response 20 - 20000 Hz - Sensitivity 95 dB
- Impedance
- 32 ohm
- Active Noise Canceling
- Microphone
- On-cable
- Controls
- Remote control
- 1-year warranty
- Product Type
- Series
- E Series
- 258 g
- Matte black
- Headband Material
- Fabric
- Recommended Use
Audio Output
- Full size
- Foldable
- Wireless
- Bluetooth
- Bluetooth Version
- Bluetooth 4.1
- Bluetooth Profiles
- Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Sound Output Mode
- Stereo
- Sound Effects
- Signature Sound
- 20 - 20000 Hz
- Sensitivity
- 95 dB
- Impedance
- 32 ohm
- Max Sound Pressure
- 108 dB
- Diaphragm
- 40 mm
Microphone
- On-cable
- Sensitivity
- -42 dB
Remote Control
- Controls
- Remote control
Wireless Link
- 2.402 - 2.480GHz
- Modulation Type
- GFSK, DQPSK
- Connector Type
- Headphones (mini-phone stereo 3.5 mm)
- Cable Details
- Headphones cable - detachable - straight , Micro-USB charge cable - detachable
- Battery
- Headphone battery rechargeable - Lithium Ion
- Capacity
- 610 mAh
- Run Time (Up To)
- 24 hour(s)
- Recharge Time
- 2 hour(s)
- Limited warranty - parts and labour - 1 year
