Move more. Get fit.
Get fit, lose weight and have fun doing it. UP MOVE™ comes in a bunch of brilliant colors that you can mix and match with accessories. Clip it on and wear it anywhere. And with an LED display and Smart Coach to guide you, the UP MOVE™ tracker doesn't just count your steps and track your sleep -- it gets you over the hump and moving on your path to a better you.
Activity Tracking
The simplest way to track your steps, exercise and overall calories burned throughout the day. Knowing this is the first step to get more active and stay motivated.
Sleep Tracking
Easily track hours slept and quality of sleep. Smart Coach learns your habits then gives you personalized suggestions to help you get to bed on time.
Smart Coach
Forget basic step counts and canned advice. Smart Coach helps you understand what changes you should make and helps you move more everyday.
In The Box
- UP Move Tracker
- UP Move Clip
- Replaceable battery
- Quick Start Guide
Materials & Care
- Device: Nylon like material
- Back Panel: Anodized aluminum with less than 0.5% nickel
- Clip: Medical grade TPU rubber
- Strap: Medical grade TPU rubber
- Splash-resistant, but do not submerge
Up Move Dimensions & Weight
- Device size: 27.64mm L x 27.64 mm W x 9.75H
- Device weight (tracker only): 6.8gm
Power & Battery
- non-rechargeable, CR2032 Lithium Coin 3V 225mAh battery
- Battery life: Up to 6 months
Sensor & Interface
- Bluetooth® 4.0 BLE
- Tri-axis accelerometer
- 12 White LEDs, 1 Orange LED, and 1 Blue LED indicate time, progress and current status
