The Jabra UC VOICE 750 is a corded headset designed specifically for Unified Communications deployments. The headset is ideal for the office professional who often uses UC voice applications. It features a lightweight design for maximum comfort all-day long. The Jabra UC VOICE 750 is made for design-conscious professionals who value a unique design.
The headset features superior sound clarity and HD Voice for softphone calls, conference calls, live presentations and other multimedia applications. The microphone includes a noise-reduction feature, ensuring that the recipient cannot hear background noise from the speaker's surroundings. This makes the headset suitable for use in louder office environments.
Easy to deploy and operate
The Jabra UC Voice 750 headset is certified and optimised with all leading Unified Communications platforms. Simply connect the headset to the computer and it is ready to use. Your IT department won't struggle with compatibility issues or time-consuming installations. The intuitive call control unit attached to the cord allows for fast user adoption.
Flexible boom-arm tip for optimal positioning
The Jabra UC Voice 750 headset has a flexible boom-arm tip to ensure the ideal microphone placement.
Two new colour models
The Jabra UC Voice 750 headset is made for design-conscious professionals who value a unique design. The headset has a thin headband and comes in both light and dark colours.
HiFi Sound
Immerse yourself in music with hi-fi sound. Listen to flawless music reproduction across the entire audible frequency range.
UC Plug-And-Play
Jabra's intelligent Call Assist lets you take a call without a click. Built-in motion sensor technology turns the headset on when you pick it up or touch it, and automatically answers the call when you place it on your ear. If you are already wearing the headset, you can accept or reject a call using just your voice.
