The Jabra UC Voice 550 is a corded headset designed specifically for unified communication deployments. The headset is made for desk-centric professionals who occasionally work from different locations and need to take the headset with them. It appeals to users favoring the classic leatherette design.
The Jabra UC Voice 550 headset features crystal-clear wideband sound and HD Voice for voice calls and multimedia while the noise-cancelling microphone filters out ambient noise.
Designed for comfort
The Jabra UC Voice 550 headset is designed for maximum comfort with soft leatherette padding on the headband and ear cushions.
Easy to deploy and operate
The Jabra UC Voice 550 headset is certified and optimised for use with all major UC platforms, is USB plug-and-play ready and features simple call control through the in-line switch on the cord. All this equals stress-free deployment and fast user uptake.
Flexible boom-arm tip for optimal positioning
The Jabra UC Voice 550 headset's flexible boom-arm allows you to position the microphone ideally for optimal voice clarity.
HiFi Sound
Immerse yourself in music with hi-fi sound. Listen to flawless music reproduction across the entire audible frequency range.
UC Plug-And-Play
Jabra's intelligent Call Assist lets you take a call without a click. Built-in motion sensor technology turns the headset on when you pick it up or touch it, and automatically answers the call when you place it on your ear. If you are already wearing the headset, you can accept or reject a call using just your voice.
