The Jabra UC Voice 150 is a corded headset designed specifically for Unified Communication deployments. It is a perfect for light use by office professionals in both small and large office environments.
The Jabra UC Voice 150 is a simple, one-step solution to getting users engaged with UC voice solutions. It is certified and optimised for use with all major UC platforms, is USB plug-and-play ready and features simple call control through the in-line switch on the cord. All this equals stress-free deployment and fast user uptake.
Crystal-clear sound
The Jabra UC Voice 150 has sound quality features you wouldn't normally expect in an entry level headset. HD Voice delivers crystal clear wideband sound for voice calls and multimedia, while the noise-cancelling microphone filters out ambient noise.
Flexible boom-arm tip for optimal positioning
The Jabra UC Voice 150 has a flexible boom tip to ensure that the user can properly position the microphone for the best possible voice clarity.
Maximum impact, minimum cost
The Jabra UC Voice 150 series is a cost-effective, quality headset from a brand you trust for those users just getting into UC voice and multimedia.
HiFi Sound
Immerse yourself in music with hi-fi sound. Listen to flawless music reproduction across the entire audible frequency range.
UC Plug-And-Play
Jabra's intelligent Call Assist lets you take a call without a click. Built-in motion sensor technology turns the headset on when you pick it up or touch it, and automatically answers the call when you place it on your ear. If you are already wearing the headset, you can accept or reject a call using just your voice.
