The Jabra TAG is the iconic Bluetooth stereo headset with FM radio that allows you to control your music and phone calls anywhere you want.
Built-in FM radio and precision sound
Jabra TAG gives you high quality stereo sound when you're on the move with noise isolating ear buds and built in FM radio. Now you can listen to your favorite tunes from your phone or your favorite radio station while you're on the go. Even when you aren't connected to a device, Jabra TAG can still provide the entertainment - it's quick and easy to tune in to the stations you want.
Swap between music and conversation
With Jabra TAG, you can keep your phone safe in your pocket while you play music, change tracks, crank up the volume and take or make calls - all wirelessly. An automatic switch makes it easy to control your music and when a call comes in, the device alerts you. With one tap you can take the call and when it ends you can go back to enjoying your tracks. It even comes with up to 7 hours of music time and 8 hours of talk time, giving you all the sound you need when you're on the move.
Wear it your way
The way you wear your Jabra TAG is up to you - you can hang it around your neck like a fashionable tag or clip it on. Either way, it's unique design means you're never out of touch - with your music or your friends.
Jabra TAG - headset
Headset - Bluetooth - wireless
Recommended Use
Portable electronics
Additional Functions
FM radio
Black, silver
Headphones Form Factor
In-ear binaural
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 3.0
Sound Output Mode
Stereo
Impedance
32 Ohm
Microphone Operation Mode
Mono
Controls
Volume
1-year warranty
FM radio
3.4 cm
0.8 cm
5.6 cm
30 g
Black, silver
Recommended Use
Max Operating Distance
10 m
Audio Output
In-ear binaural
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 3.0
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
