Introducing the world's first sports headphones with automatic VO2 Max measurement
Superior quality wireless sound & calls Enhanced wireless sound for up to 5 hours of play time.
Superior sound - now with passive noise cancellation and enhanced bass Get rid of the surrounding noise at the gym and focus on your performance! With the new COMPLY™ foam ear tips you will get superior sound quality, passive noise cancellation and enhanced bass. Jabra Sport Pulse will make sure that your favourite playlist sounds better than ever and will maximise your musical motivation.
Built-in heart rate monitor Understanding your heart rate is as simple as putting on your headphones. The built-in heart rate monitoring technology measures your heart rate via your inner ear. Jabra Sport Pulse delivers clinical-grade accuracy and ensures that you are always training at the right intensity level to improve your performance.
In-ear heart rate monitor Gold standard accuracy ensures you're always working out in the right zone.
Jabra's Sport Life™ app Get the most out of your Sport Pulse earbuds with Jabra's fitness app, which ensures you're always training in the right heart rate zone.
Plan, monitor and evaluate your performance. In-ear coaching gives you real-time feedback to help you optimise each session.
Built to US military rain, shock, sand and dust standards. "Quite simply, Pulse has the best fitting sports earbuds we've ever worn.
FREE YOUR WORKOUT WITH IMMERSIVE WIRELESS SOUND
Exercise is about breaking free, so why let wires hold you back? Get fired up by your favourite songs with immersive sound. Control music playback, volume and take calls with a quick tap on the earbuds.
IN-EAR HEART RATE MONITOR
Understanding your heart rate is now as simple as putting on your headphones. Jabra’s next generation of heart rate monitoring technology measures your heart rate via your inner ear. They’re the only earbuds proven to deliver clinical-grade accuracy. Sport Pulse ensures you always train at the right intensity level to improve your performance.
Jabra Sport Pulse Wireless - headset
Headset - Bluetooth - wireless - NFC
Recommended Use
Portable electronics
Headphones Form Factor
In-ear
Wireless
Wireless Technology
Bluetooth
Headphones Technology
Dynamic
Bluetooth Version
Bluetooth 4.0 EDR
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 94 dB
Impedance
16 Ohm
Max Input Power
5 mW
Microphone
On-cable
Controls
Volume, answer/end
1-year warranty
2.1 cm
3.2 cm
1.8 cm
16 g
Recommended Use
Max Operating Distance
10 m
Audio Output
In-ear
Dynamic
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 4.0 EDR
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Sound Output Mode
Stereo
Frequency Response
20 - 20000 Hz
Max Input Power
5 mW
Sensitivity
94 dB
Impedance
16 Ohm
Diaphragm
6 mm
Microphone
On-cable
Sensitivity
-14 dB
Frequency Response
100 - 8000 Hz
Audio Input Details
Omni-directional - 100 - 8000 Hz
Remote Control
Controls
Volume, answer/end
Tracking
Sensors
Heart rate
Wireless Link
Transmission Range
10 m
Connector Type
USB (5 pin Micro-USB Type B (power only))
Protective pouch, cable clip, 3 pairs of EarWings, 4 pairs of EarGels
