            Daily distractions and unwanted interruptions in the open office environment result in lost efficiency and poor work quality. The Jabra Busylight 14201-10 is a polite, effective way to let people know you are on the phone. A long cord allows you to place the lightwhere it easily can be seen. The indicator turns red when you are on a call and switches off when you end your call.
- Dome Shaped light guide makes it visible from all angles
- 180 degree turntable foot with double adhesive tape allows you to place the Busy Light in a prominant spot
- Powered via base unit
- Compatible with PRO9400, Motion Office, LINK850/860 & GN9330 series
