Wireless music and calls on the go
No pockets? No problem. The new Jabra PLAY is a high-performance and stylish Bluetooth® stereo headset that acts as a remote control to your mobile phone. So you can play music and take calls anywhere while leaving your phone in your pocket. Just swing it around your neck and you're on.
Switch between music and calls - seamlessly
Jabra PLAY gives you easy control of music and calls, all with high-performance digital sound quality, wireless streaming and earphones designed to isolate the noise from outside. When a call comes in the headset alerts you. With one tap you can take a call and once the call ends you can go back to enjoying your music with easy controls for volume and skipping tracks.
