Open-plan offices are becoming increasingly popular, because they improve teamwork and communication between colleagues. Unfortunately, open-plan offices also tend to be noisier than other workspaces. As many as 35% of knowledge workers say they are disturbed by colleagues talking nearby. Jabra Noise Guide is a portable device that monitors noise levels and makes people more aware of the impact noise has on their work. You can use it to identify especially noisy areas and encourage workers to reduce office noise.
Visual feedback on noise levels
Get instant visual feedback when noise levels exceed a set limit. The Instant Feedback Technology will make the unit turn red, yellow or green to make people aware of the current noise level. This encourages everyone to reduce the noise, creating a better working environment.
Measure underlying noise trends
Measure and record daily noise levels over a period of up to three months. This can help identify and track problem areas in the office. Download noise data to a PC or a USB stick and analyse it using special SoundEar 3 software.
Customise sensitivity levels for specific needs
You can customise the unit to be more or less sensitive to noise ÔÇô depending on whether it's in a quiet office or a noisier one. As your company grows, use this to set when the unit should turn green, yellow or red.
Jabra Noise Guide CUBICLE MOUNT - mounting adapter
Mounting adapter
Mounting adapter
Accessories
