WHILE STOCKS LAST
The Jabra GN9330e wireless office headset enhances the way you work. It frees you from your desk, gives you greater comfort and helps you get more done more easily.
Further, it gives you clear, peak-free sound. The boom arm with enhanced wind noise reduction together with the noise-canceling microphone technology makes sure the person you are talking to always hears you clearly, even when you're moving through those noisier areas. An extensive 9 hour talk time ensures you're always ready for action, and a cutting-edge design enables you to do business in style.
Headsets have never been more comfortable or so easy to use. A choice of wearing styles with soft and comfortable earpiece materials mean you can depend on your Jabra GN9330e for perfect comfort, and the headset connects quickly and effortlessly to your telephone. Simple and intuitive controls make it easy to operate and with a weight of only 26 grams, you'll forget you are even wearing it.
The range of up to 120 meters means you can take calls anywhere in your office environment. You can keep an optional second battery charged in the base and even hot-swap it to give you around-the-clock talk time. In short, the Jabra GN9330e frees you from the limitations of your conventional telephone handset, providing hands-free convenience and freedom of movement, all-day comfort, and superb sound clarity.
- Wireless range up to 120 meters
- Up to 9 hours of talk time
- Two wearing styles included: headband and earhook
