The Jabra FREEWAY in-car speakerphone makes hands-free calls sound better than ever - and makes controlling them effortless. It is the first in-car speaker-phone to have a 3-speaker stereo system and virtual surround sound, which makes the audio crisper, clearer and more vibrant than ever before. And with its dual-microphone technology, you can say goodbye to unwanted background noise.
The Jabra FREEWAY is extraordinarily easy to operate. That's because with the Jabra FREEWAY, voices are in control. To start with, voice guidance will talk you through setup and pairing. After that, it will announce the name of the incoming callers, ask if you want to accept their calls and will tell you battery level and connection status. You then simply use your own voice to make, answer, end, redial or reject calls - while keeping both hands safely on the wheel. And there is no need to press buttons to turn the Jabra FREEWAY on or off. It automatically turns on when you get into your car and off when you get out.
One of the first in-car speakerphones to have three speakers coupled with virtual surround sound. Sound so clear, you'll think you're talking to a passenger in the car. Also great for playing your favourite music.
FM transmitter
Prefer your car's sound system? Just use the FM transmitter to send music and calls directly to your car radio.
Dual-mic noise cancellation
Dual-mic technology filters out everything but your voice. Background noises and honking cars disappear, so the other side hears you loud and clear.
Voice guidance & control
Jabra Freeway tells you how to connect with your phone, who is calling, and your battery status. Accept, reject, end, or redial calls using just your voice.
Long battery life
With up to 14 hours of talk time and 40 days of standby time, Jabra Freeway is ready for those long road trips.
Auto on/off
Turns itself on and off automatically using the built-in motion sensor. Start the car, and your Jabra Freeway is ready to use. Once you've left the car, it turns off to save battery.
Jabra FREEWAY - speakerphone
Speakerphone - Bluetooth - wireless
Recommended Use
Portable electronics
Additional Functions
FM transmitter
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 2.1 EDR
Sound Output Mode
Surround Sound
Sound Effects
Virtual surround sound
Audio Specifications
Frequency Response 300 - 18000 Hz
Active Noise Canceling
Microphones Included
2
Controls
Mute, volume, on/off, answer/end
1-year warranty
FM transmitter
12 cm
9.9 cm
1.9 cm
115 g
Recommended Use
Max Operating Distance
10 m
Audio Output
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 2.1 EDR
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP), Phonebook Access Profile (PBAP)
