            The Jabra BIZ 1500 is an entry level, low-cost, professional corded headset with Jabra’s leading noise-cancellation technology. Designed for comfortable all-day wear.
Great sound
- Noise-cancelling Air Shock microphone reduces background noise and sharp breathing sounds – ideal for crowded open offices.
- HD Voice makes your conversations sound vibrant and lifelike.
All-day comfort
- Made to be worn all day, with ergonomically designed frame, padded headband and super soft foam ear cushions that divert heat away from your ears.
- Headband and microphone boom can be adjusted to suit your preference.
Tough Design
- Built to survive in a high-performing contact centre, with a boom-arm that can be rotated 270 degrees without the risk of breaking
