Packed with a deep feature set, this cloud-inspired Intel 3D NAND SSD is optimized for cloud infrastructures, offering outstanding quality, reliability, advanced manageability and serviceability to minimize service disruptions.
Highly efficient capacities enable more work per server to reduce TCO while increasing agility for cloud infrastructures.
Optimized for cloud storage efficiency
This cloud-inspired SSD is built with a NVMe controller, optimized for read intensive workloads and designed to maximize CPU utilization. With the Intel SSD DC P4500 Series, data centers can increase users, add more services, and perform more workloads per server. Now you can store more and know more.
Outstanding quality and reliability
With high quality and reliability, you can be confident your drives are available and your data is protected. Support for data-at-rest encryption minimizes the likelihood of data breaches, while end-to-end data protection reduces the chance of silent data errors.
Advanced manageability and serviceability
Built with advanced manageability features such as NVMe-MI, the Intel SSD DC P4500 Series allows you to remotely monitor, manage and remediate across more device states and streamline essential services.
Intel Solid-State Drive DC P4500 Series - SSD - 4 TB - PCIe 3.1 x4 (NVMe)
Solid state drive - internal
4 TB
Hardware Encryption
Encryption Algorithm
256-bit AES
NAND Flash Memory Type
3D triple-level cell (TLC)
PCIe card (HHHL)
PCIe 3.1 x4 (NVMe)
Temperature Monitoring and Logging, Enhanced Power Loss Data Protection, End-to-end data protection
5-year warranty
4 TB
Hardware Encryption
256-bit AES
PCIe card (HHHL)
PCIe 3.1 x4 (NVMe)
