The 4-inch square Intel NUC NUC5i3RYH takes the powerful capabilities of a desktop system and packages it into a computer that fits in the palm of your hand. This fully scalable system comes with 5th generation Intel Core i3 processor and integrated Intel HD Graphics with 4K display support. Whether you want a digital jukebox, home hub, or light gaming PC, the Intel NUC NUC5i3RYH gives you the power to play, create, entertain, and inspire. The system includes consumer infrared sensor so you can use a remote control for your NUC right from your couch, 7.1 surround sound, Mini HDMI video interface, and room for a 2.5" HDD or an M.2 SSD so you can store full-length movies or quickly serve up music files. With Intel WiDi you can connect your monitor without any additional cables and Bluetooth lets you place wireless speakers where you want - all the features you want in a space-saving, clutter-free design. There's also a high-speed USB 3.0 charging port that lets you easily charge your tablet or smartphone quickly. And for peace of mind you'll get embedded security that helps keep threats out, user identities and credentials safe, and your data protected.
- Built in Intel Core i3 Dual Core Processor
- Intel HD Graphics 5500 with Mini HDMI & Mini DisplayPort Outputs
- Up to 7.1 surround sound via Mini HDMI & Mini DisplayPort
- Wireless-AC M.2 Card with Bluetooth 4.0
- Gigabit Ethernet
- 4x USB 3.0 Ports
- VESA Mount Support
- Super Compact Form Factor
- Supports up to 16GB of Low Voltage DDR3L Memory (Not Included, Sold Separately)
- Supports 1x M.2 22x42, 22x60, or 22x80 SSD Card(Not Included, Sold Separately)
- Supports 1x 2.5" SATA 3 HDD/SSD up to 9.5mm thickness(Not Included, Sold Separately)
- Certified OS: Windows 8 & 8.1 (Not Included, Sold Separately)
- Compatible OS: Ubuntu, Linux Mint, Fedora, OpenSUSE (Not Included)
Note: Barebone NUCs accept Low Voltage 1.35v DDR3L SO-DIMM Modules ONLY.
