Iiyama ProLite T1931SR-B5 19" touchscreen LED Monitor - 1280 x 1024 - TN - 250 cd/m² - 1000:1 - 5 ms - HDMI, VGA, DisplayPort with speakers in matte black
Equipped with HDMI, VGA, and DisplayPort interfaces, this monitor offers versatile connectivity options for a wide range of devices, ensuring seamless integration into any workspace.
Optimal viewing experience
Featuring a 19-inch LED-backlit LCD display with a 1280 x 1024 native resolution, the iiyama ProLite T1931SR-B5 delivers crisp, clear images. The monitor's 5:4 image aspect ratio and 1000:1 contrast ratio provide vibrant colors and deep blacks, enhancing the viewing experience.
Interactive touchscreen
Incorporating 5-Wire Resistive Touch Screen Technology, this monitor allows for precise touch control, making it ideal for applications requiring touch interaction. The inclusion of a stylus further enhances accuracy for tasks that demand precision.
Ergonomic design
With display position adjustments including a tilt angle of -5/+90 degrees, users can find their optimal viewing angle, reducing strain during long periods of use. The monitor's ergonomic design promotes comfort and productivity.
Efficient and secure
The iiyama ProLite T1931SR-B5 is designed with energy efficiency in mind, classified as ENERGY STAR with a typical power consumption of 20 W. Additionally, it features a Kensington security slot for physical security.
iiyama ProLite T1931SR-B5 - LED monitor - 19"
LED-backlit LCD monitor - 19" - touchscreen
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/376495
Energy Class
Class E
Energy Consumption per Year
27 kWh
Power Consumption (On mode)
14.2 W
Touch-screen, stylus
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
1280 x 1024 at 75 Hz
Pixel Pitch
0.294 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
Display Position Adjustments
Tilt
Voltage
Matte black
43.2 cm x 21.8 cm x 39 cm
6.6 kg
Plug and Play, VCCI, GOST, DDC-2B, CB, IP54, TUV Bauart
3-year warranty
Display Type
Energy Class
Class E
27 kWh
Diagonal Size
19"
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
Pixel Pitch
0.294 mm
Brightness
250 cd/m²
Brightness w/touchscreen
200 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
31 - 80 KHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Backlight Technology
LED backlight
OSD Languages
English, German, French, Italian, Spanish, Japanese, Chinese
