ProLite T1532SR is an incredibly powerful touch solution based on the latest 5 Wire Resistive technology. Price/performance ratio is ideal for the budget conscious user while quality and specification is certainly not compromised. The display inputs include both Analog and Digital (DVI) with Touchscreen connectivity via either USB or RS-232 which offers greater than typical flexibility.
A solid and steady base supports the TouchScreen with an adjustable stand offering full 90 degree positioning angles. Extensive Touch Utilities allow for 4 point calibration and 9/25 point linearization. Menu Buttons are located on the side of the screen which can be locked to prevent tampering, and includes a handy function to deactivate the Touch Screen for cleaning. In addition the bezel free design creates an eye-catching finish with high light transmission guaranteeing perfect picture clarity and brilliant colors.
