The ProLite B2280HS is a high specification 22'‘ Full HD 1920 x 1080p LED-backlit monitor with Height Adjustability and Screen Rotation allowing you to set the perfect position of the screen ensuring ergonomic posture and optimal viewing comfort. 2ms response time and 12 000 000 : 1 Advanced Contrast Ratio make the B2280HS ideal for Video Conferencing, DTP and CAD as well as the usual text based applications. Triple Input support of Analog, DVI and DisplayPort ensures compatibility with the latest installed graphics cards and embedded Notebook outputs. The monitor is Energy Star certified.
