HyperX HX321C11SRK4/32 is a kit of four 1G x 64-bit (8GB)
DDR3-2133 CL11 SDRAM (Synchronous DRAM) 2Rx8,
memory module, based on sixteen 512M x 8-bit FBGA
components per module. Each module kit supports IntelĀ®
XMP (Extreme Memory Profiles). Total kit capacity is 32GB.
Each module has been tested to run at DDR3-2133 at a low
latency timing of 11-12-12 at 1.6V. The SPDs are
programmed to JEDEC standard latency DDR3-1600
timing of 11-11-11 at 1.5V. Each 240-pin DIMM uses gold
contact fingers.
