Attack the competition with HyperX® Savage memory. Its unique, asymmetrical red heat spreader is made from high-quality aluminum and has a black PCB and a diamond cut finish to make your game shine and help you stand out in the crowd. The heat spreader dissipates heat so your system stays cool and reliable and its low profile fits under oversized CPU coolers. Built-in, hand-tuned XMP profiles mean that even noobs can overclock their platforms with simple adjustments in BIOS.
Eye-Catching Color and Asymmetrical Design
With its aggressive design HyperX Savage memory stands out from the crowd. Combine that with asymmetrical red heat spreader and black PCB which can look great with many systems.
Intel XMP Ready
HyperX Savage is available in frequency speeds from 1600MHz to 2400MHz. You can achieve the published speeds by simply selecting the built in Intel XMP profiles in BIOS.
Lifetime Warranty with Free Technical Support
When you spend that much time building your perfect system make sure your memory lasts. With HyperX memory you get a lifetime warranty and free technical support to help you out if you’re in a tight spot.
