HyperX FURY SSD
HyperX® FURY SSD offers high performance at an affordable price, to get you in the game faster and improve boot times, application loading and file execution. Maps and levels in games load faster with increased frames per second, thanks to its SandForce® SF-2281 controller with SATA Rev 3.0 (6Gb/s) performance and read/write speeds of 500/500MB/s. HyperX FURY comes in a slim, 7mm SSD form factor to fit in most standard 2.5" notebook storage slots.
Kingston's HyperX SSD combines the SandForce controller technology with premium NAND flash, reducing load times while increasing performance and endurance. It provides high-speed SATA Rev 3.0 transfer speeds for larger bandwidth, which power users require for advanced gaming, multitasking and multimedia computing power. Kingston's HyperX SSD lets users load games and applications faster, increase frames per second (FPS) and quickly transfer and edit large media files. It's cool, silent and requires less power and no additional cooling requirements.
When configuring the HyperX SSD partition, the user can choose between having the maximum available capacity for data storage or giving up a little space to increase performance and endurance. This additional space is called over provisioning on an SSD. The amount of performance and endurance increase depends upon the type of data being stored on the HyperX SSD. The more data that is MPEG, JPG, ZIP or ARC file types, the greater the benefit for this increased over provisioning.
HyperX SSD uses an advanced wear leveling technology that distributes writes evenly across all the flash blocks in the SSD to maximize overall drive endurance. Additionally, wear leveling ensures that the individual flash memory blocks are consumed at a very balanced rate, not to exceed a 2-percent difference between the most often written blocks and least written. This enables the HyperX SSD to provide the longest possible life for the user while maintaining optimal performance.
SandForce® SF-2281 controller for SATA Rev 3.0 (6Gb/s) performance
Affordable upgrade maximizes system investment
Entry-level SSD with consistent HyperX® branding
Cool, rugged and durable, with no moving parts
