HyperX Cloud Revolver™ has a wider audio range that creates depth andwidth for improved audio precision. Get the competitive edge by hearingyour opponents’ location more accurately, even when they’re further away. Re-engineered audio profiles create a larger sound stage that’s ideal for FPSand open-environment gameplay and for a concert hall-like experience when listening to music.
It features signature HyperX™ memory foam and premium leatherette for comfort that will let you game for hours on end. Its high-quality dense memory foam is red, to differentiate it from competitors and signify award-winning HyperX comfort.
Designed in Germany, HyperX Cloud Revolver boasts a durable steel framefor long-lasting durability and stability. Its detachable noise-cancellation microphone offers clearer voice quality and reduced background noise for better in-game chats, and it’s certified by TeamSpeak™ and compatible with Discord, Skype™, Ventrilo, Mumble and RaidCall.
Next-generation 50mm drivers direct sound into the ear for precise audio positioning and a clean, crisp sound with enhanced bass. HyperX Cloud Revolver is compatible with PCs, Xbox One™1, PS4™, Wii U™, Mac® and mobile2 so it’s the only headset you need for both PC and console gaming.
Studio-grade sound stage
HyperX Cloud Revolver™ has a wider audio range that creates depth and width for optimal audio precision and a competitive edge. You’ll hear your opponents’ location more accurately from further away. Its larger sound stage is ideal for FPS and open-environment gameplay and for a concert hall-like experience when listening to music.
Next-generation directional 50mm drivers
Refined 50mm directional drivers are positioned parallel to the ears for a clean, crisp sound with enhanced bass. The drivers direct the sound into the ear for precise audio positioning.
Signature HyperX award-winning memory foam
Red memory foam is visible from back of the ear cups to differentiate HyperX from its competitors. The higher quality, dense foam signifies HyperX award-winning comfort and quality while providing ultimate comfort during prolonged gaming sessions.
2M audio control box extension with stereo and mic plugs
HyperX Cloud Revolver comes with a 2 metre audio control box extension with stereo and mic plugs for PC. It’s ideal for use with the on-board sound card.
Durable steel frame
Designed in Germany, HyperX Cloud Revolver has a solid-steel frame for long-lasting durability and stability.
Detachable noise-cancellation microphone
The removable microphone boom makes it easy to plug in for gaming or unplug to listen to music. It features a flexible design and custom mic positioning.
Multi-platform compatibility
HyperX Cloud Revolver is compatible with PC, Xbox One™1, PS4™, Wii U™, Mac® and mobile2 so you can use one headset for PC and console gaming.
TeamSpeak certified
TeamSpeak™ certifies the voice quality to be clear and crisp with excellent sound quality. No audible echoes, background noises or voice distortions were detected in tests. Other compatible chat clients include Discord, Skype™, Ventrilo, Mumble and RaidCall.
