WIDER VIEW, COMFORTABLE GRIP
The HUAWEI FullView Display features a striking 5.65-inch 2.5D glass screen that reflects vivid, true-to-life colours. The wider screen does not mean a larger body though, the thin, lightweight HUAWEI P smart fits easily in the palm of your hand.
SMART SPLIT SCREEN
The Smart Split Screen lets you run two apps side by side at the touch of a button. So when you get an important email or message while streaming TV or a movie on your HUAWEI P smart, you don't need to pause the fun.
DUAL CAMERAS, ONE AMAZING SHOT
High-spec 13MP + 2MP Dual Cameras mean top quality images at the tap of the screen. The large aperture lenses let in more light for rich, detailed, true-to-life photographs, while the Dual Camera enables perfect shallow depth-of-field bokeh shots.
HANDS-FREE SELFIE
It's never been easier to capture the moment. The HUAWEI P smart's gesture-shot function lets you take selfies and groufies with a simple wave of your hand.
Mobile Phones from BT Shop
All of the mobile phones we sell here on BT Shop are unlocked and sim-free, meaning they can be used on any network. You do not need to be a BT Mobile customer to use a phone purchased from BT Shop.
If you are looking for a great SIM Only deal, or you need a new handset with a data plan, then you need to head over to bt.com now. We can connect you to fast 4G in more places than O2, Vodafone and Three, and you’ll get free, unlimited internet access at 5 million BT Wi-fi hotspots:
BT Mobile
