Need an easy to use, affordable and reliable way to protect the data and systems critical to your small or medium business? The HP RDX Removable Disk Backup System delivers an easy-to-use, affordable and rugged data protection solution for workstations and servers. Backups are very simple with drag and drop file access. Protect your entire system with the "hands-free" HP RDX Continuous Data Protection Software which is included. Reduce cost of ownership with long lasting removable disk cartridges and a forward and backward compatible docking station that does not require a costly upgrade for future, higher capacity cartridges. The HP RDX Removable Disk Backup System offers fast disk-based performance with the ability to store 320 GB, 500 GB, 1 TB or 2 TB of data on a single removable disk cartridge at speeds of up to 360GB/hr. Portable, durable and rugged removable disk cartridges simply and securely store your backups off site for complete data protection and peace of mind.
