HP J9306A ProCurve 1500 W PoE+ ZL Redundant Power Supply For 5400zl, 8200zl Series, 5412zl Switches
Redundant power supply can be used with the HP Procurve power supply shelf (J8714A) to provide additional PoE or PoE+ power to any of the zl switches.
The HP ProCurve switch zl internal power supplies (J8712A, J8713A or J9306A) are redundant power supplies that you can add to any of the HP ProCurve zl switches to provide additional switch reliability.
- Dimensions: 5.1"(H) x 0.8"(W) x 6.3"(D)
- Compatibility: ProCurve switches 5400 zl series, 8200 zl series, 5412zl, 8212zl
- Connects devices: PC
- Output power: 1.5 kW
- Input current: 13 A at 110 VAC/10 A at 220 VAC
- Plug-in module
- Form factor: Plug-in module, internal
