As the leading 2P 2U AMD rack server, the ProLiant DL385 G7 is designed with virtualization in mind, yet flexible and expandable to support any business need in many environments from corporate data centers to sophisticated SMBs.
Latest AMD Opteron 6200 Series 16, 12, 8 and 4 Core processors.Integrated network interconnects to free up PCI slots and support more virtual machines.Up to 24 DIMM slots supporting up to 512 GB of DDR3 Memory.
The Right Fit
With up to six available PCI slots, choose from three modular configurations, including high wattage x16, legacy PCI-X, and (2) x8 dual port risers.8 or 16 SFF SAS hard drives with up to 16 TB, or 6 LFF hard drives for up to 18 TB of internal storage.Choose from 460W AC, 750W AC , 1200W AC or -48V DC power supplies, 92% or 94% Efficiency.Embedded Modular SmartArray storage controllers and your choice of cache size and BBWC or FBWC options.
Virtual Perfection
Robust memory and NIC features to support more virtual machines and compute intensive business needs.HP Insight Control tools allows you to manage both physical and virtual IT through a single console.Get virtual machines deployed easily and securely.
Focus on Energy Efficiency
92% and new 94% efficiency power supplies saves energy costs.HP Thermal Logic provides robust power management.
HPE ProLiant DL385 G7 Performance - rack-mountable Opteron 6180 SE 2.5 GHz - 16 GB - no HDD
Server - rack-mountable - administrator password, power-on password, keyboard password, serial port I/O control, quick lock
1 (total) / 0 (free) x external 5.25" Slim Line , 8 (total) / 8 (free) x hot-swap 2.5" SFF
Slots
1 (total) / 1 (free) x PCIe 2.0 x16 - full-length, full-height (x8 mode) , 2 (total) / 1 (free) x PCIe 2.0 x8 - half-length, full-height (x4 mode) , 2 (total) / 0 (free) x CPU , 24 (total) / 16 (free) x DIMM 240-pin
1 x serial , 1 x PS/2 keyboard , 1 x PS/2 mouse , 2 x VGA (1 front, 1 rear) , 4 x LAN (Gigabit Ethernet) , 1 x HPE iLO , 4 x USB 2.0 (2 front, 2 rear)
Administrator password, power-on password, keyboard password, serial port I/O control, quick lock
ACPI 2.0, FCC Class A certified, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, BSMI CNS 13438
Power supply
Power Redundancy
Power Redundancy Scheme
1+1
Installed Qty
2
Max Supported Qty
2
Power Provided
750 Watt
Operating System / Software
Software
HP Insight Control
Limited warranty - parts and labour - 3 years - on-site - response time: next business day
