Back
Enterprise Storage
HPE 160GB NON HOT-PLUG 7.2K RPM SA
Quicklinx:
57SSWS00
Mfr#:
458947-B21
Back
HP 160GB 3G SATA 7.2K rpm LFF (3.5-inch) Non-hot Plug Entry 1yr Warranty Hard Drive
HPE Entry - hard drive - 160 GB - SATA 3Gb/s
Hard drive - internal
160 GB
3.5" x 1/3H
SATA 3Gb/s
Data Transfer Rate
300 MBps
Spindle Speed
7200 rpm
1-year warranty
ProLiant DL120 G5 (3.5"), DL120 G6 (3.5"), DL160 G5 (3.5"), DL160 G5p (3.5"), DL160 G6 (3.5"), DL160 G6 Special Server (3.5"), DL160se G6 (3.5"), DL165 G5 (3.5"), DL165 G5 Special Server (3.5"), DL165 G6 (3.5"), DL165 G7 (3.5"), DL165 G7 Base (3.5"), DL165 G7 Entry (3.5"), DL165 G7 Special Server (3.5"), MicroServer (3.5"), ML110 G5 (3.5"), ML110 G6 (3.5"), ML110 G7 (3.5"), ML110 G7 Base (3.5"), ML110 G7 Entry (3.5"), ML115 G5 (3.5"), ML115 G5 Special Server (3.5"), ML150 G5 (3.5"), ML150 G6 (3.5"), ML150 G6 Entry (3.5"), ML330 G6 (3.5"), ML330 G6 Entry (3.5")
160 GB
3.5" x 1/3H
SATA 3Gb/s
Performance
Drive Transfer Rate
300 MBps (external)
Spindle Speed
7200 rpm
Expansion & Connectivity
1 x SATA 3 Gb/s
Compatible Bay
3.5" x 1/3H
Limited warranty - parts and labour - 1 year
HPE ProLiant DL120 G5 (3.5"), DL120 G6 (3.5"), DL160 G5 (3.5"), DL160 G5p (3.5"), DL160 G6 (3.5"), DL160 G6 Special Server (3.5"), DL160se G6 (3.5"), DL165 G5 (3.5"), DL165 G5 Special Server (3.5"), DL165 G6 (3.5"), DL165 G7 (3.5"), DL165 G7 Base (3.5"), DL165 G7 Entry (3.5"), DL165 G7 Special Server (3.5"), MicroServer (3.5"), ML110 G5 (3.5"), ML110 G6 (3.5"), ML110 G7 (3.5"), ML110 G7 Base (3.5"), ML110 G7 Entry (3.5"), ML115 G5 (3.5"), ML115 G5 Special Server (3.5"), ML150 G5 (3.5"), ML150 G6 (3.5"), ML150 G6 Entry (3.5"), ML330 G6 (3.5"), ML330 G6 Entry (3.5")
