Back
Refinements
HPE - hard drive - 300 GB - SAS 12Gb/s
Quicklinx:
GK1ZWS00
Mfr#:
873031-001
Back
Marketing description is not available.
Hard drive
300 GB
2.5" SFF
SAS 12Gb/s
Data Transfer Rate
1.2 GBps
Spindle Speed
15000 rpm
Digitally Signed Firmware, Dual Port
Bundled with
HPE Standard Carrier
ProLiant BL20p G4, BL45p G2, BL460c G6, BL460c G7, BL465c G5, BL465c G6, BL465c G7, BL480c, BL620C G7, BL680c G5, BL680c G7, BL685c G6, BL685c G7, DL120 G6, DL120 G7, DL160 G6, DL160se G6, DL165 G6, DL165 G7, DL170E G6, DL170h G6, DL180 G6, DL320 G6, DL360 G4, DL360 G5, DL360 G6, DL360 G7, DL365 G5, DL370 G6, DL380 G4, DL380 G5, DL380 G6, DL380 G7, DL385 G2, DL385 G5 (2.5"), DL385 G6 (2.5"), DL385 G7 (2.5"), DL580 G3 (2.5"), DL580 G4 (2.5"), DL580 G5 (2.5"), DL580 G7 (2.5"), DL585 G2 (2.5"), DL585 G5 (2.5"), DL585 G6 (2.5"), DL585 G7 (2.5"), DL785 G6 (2.5"), ML110 G7 (2.5"), ML350 G5 (2.5"), ML350 G6 (2.5"), ML370 G5 (2.5"), ML370 G6 (2.5"), ML570 G3 (2.5"), ML570 G4 (2.5"), SL390s G7 (2.5")
Hard drive
300 GB
2.5" SFF
SAS 12Gb/s
Bundled with
Performance
Drive Transfer Rate
1.2 GBps (external)
Spindle Speed
15000 rpm
Expansion & Connectivity
1 x SAS 12 Gb/s
Compatible Bay
2.5" SFF
HPE ProLiant BL20p G4 (2.5"), BL45p G2 (2.5"), BL460c G6 (2.5"), BL460c G7 (2.5"), BL465c G5 (2.5"), BL465c G6 (2.5"), BL465c G7 (2.5"), BL480c (2.5"), BL620C G7 (2.5"), BL680c G5 (2.5"), BL680c G7 (2.5"), BL685c G6 (2.5"), BL685c G7 (2.5"), DL120 G6 (2.5"), DL120 G7 (2.5"), DL160 G6 (2.5"), DL160se G6 (2.5"), DL165 G6 (2.5"), DL165 G7 (2.5"), DL170E G6 (2.5"), DL170h G6 (2.5"), DL180 G6 (2.5"), DL320 G6 (2.5"), DL360 G4 (2.5"), DL360 G5 (2.5"), DL360 G6 (2.5"), DL360 G7 (2.5"), DL365 G5 (2.5"), DL370 G6 (2.5"), DL380 G4 (2.5"), DL380 G5 (2.5"), DL380 G6 (2.5"), DL380 G7 (2.5"), DL385 G2 (2.5"), DL385 G5 (2.5"), DL385 G6 (2.5"), DL385 G7 (2.5"), DL580 G3 (2.5"), DL580 G4 (2.5"), DL580 G5 (2.5"), DL580 G7 (2.5"), DL585 G2 (2.5"), DL585 G5 (2.5"), DL585 G6 (2.5"), DL585 G7 (2.5"), DL785 G6 (2.5"), ML110 G7 (2.5"), ML350 G5 (2.5"), ML350 G6 (2.5"), ML370 G5 (2.5"), ML370 G6 (2.5"), ML570 G3 (2.5"), ML570 G4 (2.5"), SL390s G7 (2.5")
