HP introduces a new Performance Series monitor, the HP ZR24w, with the extreme visual performance, 8-way comfort adjustments and power-saving features your business demands.
The ZR24w delivers outstanding visual performance with its S-IPS panel for enhanced color accuracy at ultra-wide viewing angles, 16.7M displayable colors, 1920 x 1200 resolution, 5 ms response time and 3000:1 dynamic contrast ratio.
Responsible
The ZR24w has an 85% efficient power supply, while the chassis is made up of least 25% recycled resin, so you can be confident the ZR24w has the responsible features your business requires.
Productive
The HP ZR24w enables maximum comfort and best visual positioning with an 8-way comfort adjust stand that provides tilt, pivot, swivel and column height adjustability, so you can increase your comfort and productivity throughout the day.
Better together
HP Z Workstations (sold separately) are tested with all HP Performance displays and also feature complimentary industrial design and high efficiency power supplies for a smart and power-efficient workstation solution.
HP ZR24w - LCD monitor - 24" - Smart Buy
LCD monitor - 24"
USB 2.0 hub
Panel Type
S-IPS
Aspect Ratio
16:10
Native Resolution
1920 x 1200 at 60 Hz
Pixel Pitch
0.27 mm
Brightness
400 cd/m²
Contrast Ratio
1000:1 / 3000:1 (dynamic)
Response Time
7 ms
Colour Support
16.7 million colours
Colour Gamut
83%, 72% NTSC
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Voltage
Carbonite
55.6 cm x 23.5 cm x 42.5 cm
8.5 kg
English / United Kingdom
Manufacturer Selling Program
HP Smart Buy
Microsoft Certification
Certified for Windows Vista
Environmental Standards
ENERGY STAR Qualified
Plug and Play, CSA, TUV, VCCI, GS, ISO 13406-2, FCC, RoHS, WEEE, ACA, CISPR
3-year warranty
Display Type
LCD monitor / TFT active matrix
Diagonal Size
24"
Built-in Devices
USB 2.0 hub
Panel Type
S-IPS
Aspect Ratio
16:10
Native Resolution
Pixel Pitch
0.27 mm
Brightness
400 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
83%, 72% NTSC
Response Time
7 ms
Vertical Refresh Rate
61 Hz
Horizontal Refresh Rate
80 kHz
Video Bandwidth
200 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Colour Temperature
9300K, 5000K, 6500K
Controls & Adjustments
Brightness, contrast, colour temperature, clock
OSD Languages
Chinese (traditional), Chinese (simplified), Brazilian Portuguese, English, German, French, Italian, Spanish, Dutch, Japanese
