Conquer the workday with the perfect combination of brains and beauty. The iconic 39,6 cm (15.6") diagonal HP ZBook Studio is HP's thinnest, lightest, and most attractive full performance mobile workstation.
Brilliant inside and out
Make a bold statement with innovative style and performance. Starting at just 1.99 kg (4.4 lbs) and 18mm thin, the HP ZBook Studio is a meticulously-designed performance machine.
Create your ideal workstation
Get looks and performance with Intel Xeon processor options, dual 1 TB HP Z Turbo Drive G2 for up to 2 TB of total storage, up to 32 GB ECC memory, dual Thunderbolt 3, and optional HP DreamColor UHD or FHD touch displays.
Defined by HP Z DNA
Work confidently with HP mobile workstations designed around 30 years of HP Z DNA with extensive ISV certification. It's reliable, designed to pass MIL-STD 810G testing, and endure 120K hours in HP's Total Test Process.
