Get the ultimate blend of design and performance in the next generation HP ZBook Studio. Speed through your work and bring your ideas to life on HP's brightest 4K laptop.
Be productive in any situation. Windows 10 Pro and powerful security, collaboration, and connectivity features from HP help you power through your day on the HP ZBook Studio.
8th gen Intel Core i9 or Intel Xeon processors
Do more at once with next-generation 6-core Intel Core i9 or Intel Xeon processors designed to handle complex, multi-threaded applications like Adobe Premier Pro.
NVIDIA Quadro 3D Graphics
Seamlessly edit your designs and render multi-layered files with certified NVIDIA Quadro P2000 graphics, optimized for stability and performance with professional software apps.
Blazing fast storage
Create seamlessly. Save and access large files locally with up to 4 TB local NVMe storage, up to 21 times faster than standard HDD storage and six times faster than SATA SSD.
Large memory configurations
Get remarkable, real time performance running multiple applications simultaneously with up to 64 GB RAM.
Fast charging and long battery life
Take your work on the road with up to 16 hours of battery life for maximum productivity. When you need it, recharge ultra-fast (50% in just 45 minutes).
HP ZBook Studio G5 Mobile Workstation - 15.6" - Intel Core i7 8750H - 8 GB RAM - 256 GB SSD - UK
Power-on password, One-Step Logon, Setup Password, Automatic DriveLock, BIOS Absolute Persistence, HP DriveLock, Measured Boot, Power On Authentication, Pre-boot Authentication, Secure Erase, HP Sure Start Gen 4, HP Sure Run, HP Sure Recover, BIOS Update via Network, HP Sure Click
