Be productive in the office or in the field. Take advantage of the HP ZBook 15 G2's powerful processing and graphics, simple scalability, and blazing-fast connectivity to perform and collaborate at the speed of creativity.
Rest easy with a ZBook 15 G2 that has ISV Certifications and has undergone 115,000 hours of the HP Total Test Process.
Scale up to what you need
Customize the HP ZBook 15 G2 to meet your demands. Keep large files at your fingertips without sacrificing performance with three internal storage devices with up to 2.2 TB storage and 32 GB memory.
Set a new performance curve for your ZBook 15
Handle large files, reduce work time and increase performance with the HP Z Turbo Drive.
The power of Thunderbolt
Connect in a flash with 4X USB 3.0 speeds and enhance productivity with a high-performance Thunderbolt 2 port on the ZBook 15 G2.
Work virtually anywhere
Access and share your workstation or server-based graphic-rich applications from any PC, thin client or Windows tablet with HP Remote Graphics Software.
Optimized workstation-class graphics
Run the same demanding professional applications as a desktop workstation without dropping performance. ISV certified NVIDIA Quadro graphics options offer large GPU memory with fast bandwidth.
HP ZBook 15 G2 Mobile Workstation - 15.6" - Intel Core i7 - 4710MQ - 4 GB RAM - 1 TB HDD - UK
Mobile workstation
Operating System
Win 7 Pro 64-bit (downgrade from Windows 8.1 Pro) + Windows 8.1 Pro Licence - English
Intel Core i7 (4th Gen) - 4710MQ / 2.5 GHz, up to 3.5 GHz / 6 MB Cache
VGA , DisplayPort , Thunderbolt 2 , Headphone/microphone combo jack , LAN , 3 x USB 3.0 , USB 2.0 , Battery , Dock
Memory Card Reader
Yes (SDHC Card, SDXC Card, SDXC UHS-II Card)
Software
Software Included
Cyberlink PowerDVD, CyberLink PowerDirector, CyberLink Power2Go, Adobe Flash Player, Skype, Microsoft Security Essentials, HP Remote Graphics Software, HP Recovery Manager, HP Support Assistant, HP Connection Manager, HP Hotkey Support, PDF Complete Corporate Edition, HP Performance Advisor, CyberLink YouCam BE, CyberLink Media Suite, CyberLink PhotoDirector, HP Client Security, CyberLink YouCam Webcam Sharing Manager
Charging via USB, HP 3D DriveGuard, HP DuraFinish, HP SpareKey, One-Step Logon, HP File Sanitizer, HP DuraCase, HP DisplaySafe, HP BIOS Protection, HP SureStart, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security
