Join the Ultra High Definition movement and expand your visual workspace with the HP Z27s 68,6 cm (27") IPS UHD Display, which delivers an extra-large screen with UHD/4K presentation and flexible connectivity and comfort features.
Find your sweet spot with customizable tilt, height adjustment, swivel, and pivot settings-plus an integrated HP Quick Release that allows you to mount the display on a wall.
Meet your monitor's new best friend
Design the screen for how you work with HP Display Assistant software.
Designed with the environment in mind
Be a better consumer with a display that has environmentally responsible components that include low halogen, arsenic-free glass, and mercury-free backlights.
With stand - width: 62.56 cm - depth: 24.24 cm - height: 53.59 cm - weight: 7.8 kg , Without stand - width: 62.56 cm - depth: 6.09 cm - height: 37.03 cm - weight: 5.4 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 5 years - on-site - response time: next business day
