Redefine life like image presentation with the HP Z27q 68,6 cm (27') IPS 5K Display, which delivers more screen real estate and color clarity with an astounding 5K resolution.
Enjoy accurate color calibration for sRGB, Adobe RGB, and BT.709-the same color space as Blu-ray media-from the very first time you power on.
Extraordinary color
Get smoother gradations, clearer images, and unbelievably rich color presentation on all your projects from the professional grade, 10-bit color quality and up to 1.07 billion colors.
HP Z27q - LED monitor - 27"
LED-backlit LCD monitor - 27"
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
5K Ultra HD (2880p) 5120 x 2880 at 60 Hz
Brightness
300 cd/m²
Response Time
8 ms (grey-to-grey)
Colour Support
1.07 billion colours
Colour Gamut
99% Adobe RGB
Input Connectors
2xDisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
AC 120/230 V
63.43 cm x 21.71 cm x 38.03 cm
7.42 kg
English / United Kingdom
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Plug and Play
Display Type
Diagonal Size
27"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Per Inch
218
Brightness
300 cd/m²
Colour Support
Colour Gamut
99% Adobe RGB
Response Time
8 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
HDCP
63.43 cm x 21.71 cm x 38.03 cm - with stand
7.42 kg
2 x DisplayPort (HDCP) , 4 x USB 3.0 downstream , USB 3.0 upstream
Mechanical
Tilt Angle
-5/+22
Swivel Angle
360
Plug and Play
Security Slot Type
Kensington security slot
Input Voltage
AC 120/230 V
Power Consumption (Typical)
80 Watt
Power Consumption Stand by
0.5 Watt
Dimensions & Weight Details
With stand - width: 63.43 cm - depth: 21.71 cm - height: 38.03 cm - weight: 7.42 kg , Without stand - width: 63.43 cm - depth: 6.2 cm - height: 38.034 cm
