Deploy a seamless multi-display setup with the HP Z24nf Narrow Bezel IPS Display, which delivers Full HD, factory color calibration, and flexible connectivity for all of your devices.
Experience edge-to-edge 1920 x 1080 resolution on a three-sided borderless 60,45 cm (23.8") diagonal screen that enables uninterrupted views of multiple displays.
Factory-integrated color calibration
Get reliable color accuracy across all of your projects with out-of-the-box color calibration that's ready to go the very first time you turn on your display.
Build a better workspace
Connect to your everyday devices with integrated HDMI, mDP, DP, MHL, DVI, and a USB 3.0 hub with a fast-charging port. A DisplayPort output allows you to daisy chain up to four displays with just one PC or workstation connection.
HP Z24nf - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class A
Energy Consumption per Year
31 kWh
Power Consumption (On mode)
21 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.27 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
8 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
95% sRGB
Input Connectors
HDMI, DVI-D, 2xDisplayPort, MHL
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
54.06 cm x 21.01 cm x 50.55 cm
5.2 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
UL, VCCI, C-Tick, BSMI, WHQL, CCC, FCC, KC, CECP
3-year warranty
Display Type
Energy Class
Class A
31 kWh
Diagonal Size
23.8"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.27 mm
Pixel Per Inch
92.6
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
95% sRGB
Response Time
8 ms (grey-to-grey)
Vertical Refresh Rate
50 - 60 Hz
Horizontal Refresh Rate
30 - 75 kHz
Video Bandwidth
170 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
Controls & Adjustments
Brightness, input select
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
HDCP
54.06 cm x 21.01 cm x 50.55 cm - with stand
5.2 kg
DVI-D (dual link) (HDCP) , MHL / HDMI (HDCP) , DisplayPort (HDCP) , DisplayPort output , 4 x USB 3.0 downstream , USB 3.0 upstream , Audio line-out
Mechanical
Tilt Angle
-2/+22
Swivel Angle
45
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand, 1 USB 3.0 charging port, HP Quick Release 2
1 x DisplayPort cable - 1.8 m , 1 x USB cable - 1.8 m
Backlight Life
30,000 hours
Security Slot Type
Kensington security slot
Input Voltage
21 W
Power Consumption (Typical)
45 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
On / Off Switch
Dimensions & Weight Details
With stand - width: 54.06 cm - depth: 21.01 cm - height: 50.55 cm - weight: 5.2 kg , Without stand - width: 54.06 cm - depth: 5.04 cm - height: 32.34 cm - weight: 3.3 kg
