Create a seamless 16:10 multi-display setup with the HP Z24n Narrow Bezel IPS Display, which has a virtually borderless screen for maximum impact imagery, factory color calibration to ensure optimal color accuracy, and flexible connectivity for all of your devices.
Virtually borderless viewing.
Enjoy a stunning visual experience with a 1920 x 1200 resolution and more than two million pixels. Maximize your view of the 61 cm (24") diagonal screen and seamlessly tile multiple displays with a design that only has a border on one side.
Ports aplenty for a perfect workspace.
Connect to your everyday devices with integrated HDMI, mDP, DP, MHL, DVI, and a USB 3.0 hub with a fast-charging port. The DisplayPort output allows you to daisy chain up to two displays with just one PC or workstation connection.
Out-of-the-box color.
Count on a factory-calibrated 99% sRGB color gamut from the very first time you power on for reliable, accurate color between displays and from project to project.
