Be more productive on the go with the sleek, stylish HP X4000b Bluetooth Mouse that's comfortable wherever you work best and complements your HP Business Notebook, Ultrabook or tablet PC.
The compact, cordless design fits easily into a carrying case alongside your notebook, tablet or Ultrabookâ˘.
The mouse works seamlessly with Bluetooth-enabled laptops, Ultrabook⢠PCs, and tablets without taking up a valuable USB port. A helpful LED indicator light verifies your connection and alerts you when the battery runs low.
The high-precision 1600 dpi laser sensor works on most surfaces so you can stay productive wherever the day takes you. The rubber-edge grips make the mouse comfortable and easy to handle in either hand.
