Attach your HP Desktop Mini, HP Chromebox or select HP Thin Client directly behind the display for an integrated, affordable workspace.
Designed with the environment in mind
Reduce power consumption and help lower your costs with an energy-smart, EPEAT 2019 registered design.
Your monitor's new best friend
Design the screen for how you work with HP Display Assistant software, which enables screen partitioning and helps deter theft by deactivating a monitor that's disconnected without approval.
Make it yours
Create a complete solution with HP accessories designed and tested to work with your display.
World-class support
Rest assured that your IT investment is supported by a four-year standard limited warranty. To extend your protection, select an optional HP Care service.
HP VH27 - LED monitor - Full HD (1080p) - 27" - Smart Buy - TAA Compliant
Without stand - width: 62.15 cm - depth: 4.6 cm - height: 37.16 cm - weight: 3.98 kg , With stand - width: 62.15 cm - depth: 21.8 cm - height: 52.52 cm - weight: 6.1 kg
