Back
Refinements
HP USB-C LC Power Adapter - 65 Watt
More than 50 In Stock
Quantity to buy of HP USB-C LC Power Adapter - 65 Watt
£14.85
ex VAT
Add to regular buy list
Buy
Quicklinx:
H6WSWS00
Mfr#:
1P3K6AA#ABU
Back
Charge your laptop in the office or on the go with the HP USB-C LC Power Adapter.
Easy to use
Connect one end of the adapter to the USB-C port on your device, and plug the AC head into any available wall outlet.
Carry and store with your device
Pack the compact adapter inside your device's carrying case for easy, convenient charging and power whenever you need it.
HP USB-C LC - power adapter - 65 Watt
Power adapter - external
English / United Kingdom
Input Voltage
AC
Power Capacity
65 Watt
Pro c640 G2 Chromebook; ProBook 635 Aero G7 Notebook
Input Voltage
AC
Power Capacity
65 Watt
HP Pro c640 G2 Chromebook , HP ProBook 635 Aero G7 Notebook
