Get a powerful and seamless desktop experience, enhanced security features, and premium client virtualization from the HP t620 PLUS Flexible Series Thin Client.
Customize your thin client with everything you need and nothing you don't. Choose the configuration options and expansion capabilities that best fit your business and help ensure an ideal end user experience.
Tailor your hardware and software performance to your exact requirements
Configure your deployment to provide a powerful seamless desktop experience for your end users without exceeding your budget.
Customize security the way you want
Help protect your thin client environment with integrated and optional hardware and software security solutions, including: HP BIOS implemented to NIST guidelines, a TPM chipset, Fiber NIC communications, and lockable covers and ports.
Designed to give you peace of mind
Reduce desktop service calls and product refreshes with a completely redesigned chassis that includes advanced passive cooling for fan-less support of quad-core processors.
HP Flexible t620 PLUS - tower - GX-420CA 2 GHz - 4 GB - SSD 8 GB - UK - TAA Compliant
Citrix ICA, Microsoft RDP, HP ThinState Tools, Citrix XenDesktop Standard Edition, HP Connection Manager, HP Easy Tools, HP Device Manager, Citrix HDX, HP Velocity, Citrix Receiver 12.1.5, FreeRDP 1.0, Microsoft RemoteFX, HP Cloud Connection Manager, VMware Horizon View 2.1, HP TeemTalk Terminal Emulator 7.3.3, Mozilla Firefox 19
6.5 cm x 22 cm x 24 cm
2.04 kg
TAA Compliant
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years
Thin client
Recommended Use
Small business, corporate business
Product Form Factor
Tower
Built-in Devices
Speaker
Processor / Chipset
CPU
AMD GX-420CA
Clock Speed
2 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Not upgradable
Cache Memory
Installed Size
L2 Cache - 2 MB
Cache Per Processor
2 MB
RAM
Installed Size
4 GB / 16 GB (max)
DDR3L SDRAM
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
SO-DIMM 204-pin
Slots
2 (Total) / 1 (empty)
Low-voltage
Configuration Features
1 x 4 GB
Hard Drive
SSD - M.2
1 x 8 GB
Interface Type
SATA
Multi-level cell (MLC)
Storage Controller
1 x SATA - integrated
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
AMD Radeon HD 8400E
Video Interfaces
DisplayPort
Audio Output
Integrated
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP Standard Keyboard
USB
Localization & Layout
Mouse
USB
Integrated
Wake on LAN (WoL), DHCP support, PXE support
Slots
1 (total) / 1 (free) x mSATA , 2 (total) / 1 (free) x SO-DIMM 204-pin , 1 (total) / 1 (free) x PCIe Mini Card , 1 (total) / 1 (free) x PCIe x16 (x4 mode) , 1 (total) / 0 (free) x M.2 Card
6 x USB 2.0 (2 front, 2 rear) , 2 x USB 3.0 (2 in front) , 2 x DisplayPort , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) , 1 x headphones (1 in front) , 1 x microphone (1 in front) , 1 x audio line-in , 1 x audio line-out , 1 x parallel , 2 x serial
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
FCC Class B certified, TUV GS, VCCI, UL 1950, CSA 22.2 No. 950, EN55022 Class B, RoHS, WEEE
TAA Compliant
Power adapter
Power Provided
85 Watt
Operating System / Software
OS Provided
HP ThinPro 32-bit English
OS Certified
Microsoft Windows Server 2003, Citrix Presentation Server 4.0, Citrix XenDesktop 3.0, Citrix XenApp 5, Microsoft Windows Server 2012
Software
