Get the best bang for your investment buck with AMD GX-212JC SOC (System on Chip), HD graphics, and expansive memory and storage.
Place it where you need it
Make the most of your available workspace and deploy the sleek, new, fanless chassis horizontally or vertically in a range of compact settings.
Keep it simple
Make it easy to deploy, manage, and maintain your install base with HP Device Manager, a software tool available exclusively for HP Thin Clients.
High quality LAN-like data delivery
Improve network performance and the end-user experience with HP Velocity software.
Get the right OS for your environment and budget
Select a Windows OS for a familiar Windows experience with Enhanced Write Filter security and added multi-touch support, HP ThinPro for full-featured Linux or HP Smart Zero Technology for simple management.
No-hassle virtualization
Connect to your virtualized desktops and applications with support for the latest ISVs and certifications from Citrix, VMware, and Microsoft.
Citrix ICA, Microsoft RDP, HP ThinState Tools, HP Easy Tools, HP Device Manager, VMware Horizon View, Citrix HDX, Microsoft RemoteFX, Mozilla Firefox 19
1 (total) / 0 (free) x SO-DIMM 204-pin , 1 (total) / 0 (free) x M.2 Card , 1 (total) / 0 (free) x PCIe Half Mini Card
2 x USB 3.0 (2 in front) , 4 x USB 2.0 , 2 x DisplayPort , 1 x VGA , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out/headphones - mini-jack (1 in front) , 1 x audio line-in/microphone - mini-jack (1 in front)
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
TUV GS, VCCI, UL 1950, EN55022 Class B, FCC, RoHS, AES-128, low halogen
Power adapter
Power Provided
65 Watt
Operating System / Software
OS Provided
HP ThinPro 32-bit
Software
