Upgrade classroom learning with the thin, light, and powerful HP Stream 11 Pro. Take learning to another level, while maximizing collaboration using stable and reliable connectivity.
From the start of class to after-school homework, stay productive with the Stream 11 Pro's long battery life.
Budget friendly, classroom ready
This budget friendly notebook is built for learning with WLAN for easy connectivity in the classroom, hardware and firmware TPM for security, fast boot-up time, and 5th Gen Intel Celeron processing power.
Sleek style, quiet operation
The ultra-slim quiet fan-less design helps keep classrooms focused without the ambient noise from multiple machines.
Extra security
The embedded Trusted Platform Module 2.0 (TPM) provides hardware-based encryption keys to help secure data, e-mail, and login credentials.
HP Stream Pro Laptop 11 G3 - 11.6" - Intel Celeron - N3060 - 4 GB RAM - 64 GB eMMC - UK
Notebook
Operating System
Win 10 Home 64-bit - English
Intel Celeron N3060 / 1.6 GHz, up to 2.48 GHz / 2 MB Cache
4 GB DDR3L (provided memory is soldered)
Storage
64 GB eMMC
Display
11.6" WLED 1366 x 768 / HD
Graphics
Intel HD Graphics 400
Input Device
ClickPad
Keyboard
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2
2-cell
Security
Trusted Platform Module (TPM 2.0) Security Chip
30 cm x 20.56 cm x 1.8 cm
1.17 kg
Environmental Standards
- ENERGY STAR Qualified EPEAT Climate+
Notebook
Operating System
Windows 10 Home 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
2.48 GHz
Number of Cores
Dual-Core
Cache
2 MB
64-bit Computing
RAM
4 GB (provided memory is soldered)
DDR3L SDRAM
Speed
1600 MHz / PC3L-12800
Rated Speed
1600 MHz
Storage
Main Storage
64 GB eMMC
Display
11.6" - TN
LCD Backlight Technology
WLED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Brightness
220 cd/m²
HD standard-viewing angle (SVA) eDP anti-glare
Audio & Video
Graphics Processor
Camera
Yes - VGA
Video Resolutions
640 x 480
Frame Rate
24 frames per second
Camera Features
Noise reduction
Sound
Stereo speakers, microphone
Codec
Realtek ALC3227
High Definition Audio
Input
Keyboard, ClickPad
Keyboard Layout
Multi-touch clickpad
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-AC 8260 - PCI Express Mini Card (M.2)
Dual stream (2x2)
IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
2-cell lithium polymer
37.69 Wh
AC Adapter
Input
Output
45 Watt, 19.5 V
Connections & Expansion
Interfaces Details
USB 2.0 , USB 3.0 , HDMI
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Software
Software Included
HP Support Assistant, HP ePrint, McAfee LiveSafe, McAfee Checkbox, HP JumpStart
