The sleek, precision-crafted HP Spectre Pro x360 offers the benefits of flexible 360 degree hinge movement and four operating modes. Stay productive with long battery life on an x360 business convertible with 6th Gen Intel Core i5/i7 processors and optional vPro.
Break from the conventional with 360o flexibility.
Sturdy lightweight aluminum creates a seamless look on this incredibly thin (.61 in. / 15.4 mm.) convertible PC. Starting at just 3.2lbs / 1.45kg, easily switch between four different user modes on the 33,8 cm (13.3") diagonal touch FHD or QHD touchscreen.
Power for hours
Never slow down with long battery life that allows you to create, stay productive, and entertain without having to recharge.
Premium performance
Take charge of your workday with Windows 10 Pro and powerful 6th Gen Intel® Core™ processors with optional vPro™ technology.
Field ready
Never fear bumps and minor spills. The thin and light HP Spectre Pro x360 is designed to undergo MIL-STD 810G testing.
